motorhome tyre pressure ????
seanb
Hi all I have a elnagh marlin 65 motorhome on a 2.8 fiat ducato chassie. Does anyone know the correct tyre pressures for this van . fiat book states 80psi / 5.5bar as does the label on door this seems alot to me but is it correct ??
could be, experiment 5-10 psi lower and see if you like the ride .then keep your eyes on tread wear. its all trial and error work . cheers alan.
important thing is the maximum axle weights which you use , and the rating of the tyres fitted
if you look on the fiat plate [ under the bonnet ]it will give the axle as well as the vehicle maximum . so post that as well as the load index of the tyre ...at a guess you have 109/107 215/70 15
Sounds about right, we have the 2.8 Ducato chassis and run at 5.5 bar.
There is only one way to find the correct pressure.
Load up your van to a typical trvelling condition ie: Fuel, water, passengers and general kit, then go on a weighbridge to check the axle weights. You will get a printed ticket with the values on.
Go to tyresafe.org/data/files/motorhome%2008.pdf
You can work out the pressure for your size of tyre from that.
Running at 5.5 bar means you are very close to the maximum rated pressure for your tyres. In fact it exceeds the max. for some brands.
I had the same problem a few years ago and found it very difficult to get the correct pressure. As it happened, there was a weighbridge where I was working. When I got the axle weights, I phoned up Michelin who gave me the correct information. I had been running at more than 20 psi too much. The difference in handling and the smoother ride were very different afterwards.
I believe that the tyre companies have stopped handing out this info. but it is worth a try.
If you do not know your axle loading then you have no idea if you are overloaded on one or both axles. As VOSA are pulling over m/homes on a regular basis, you are liable for a fine or worse. They are keen to pull m/homes over because of the ones they have stopped, a good percentage were overloaded.
maingate is 100% correct
tyres should be run at the correct pressure for the load they carry
so first you ascertain the load , then you set the tyre pressure according to the recommendations of the ETRTO
at a guess we are talking of 215R70 15 109/107 load index here
this tyre is capable of carrying 1030Kg in single formation , 2060Kg per axle
if you are running your 3,500Kg vehicle at 2,060Kg per axle 5.5 bar is the correct pressure on rear driven axles , 4.75 bar otherwise ; I trust you are not running at these weights !
I run my vehicle on this size tyre at 1500Kg front axle , and 1900Kg rear axle , and for this I use 4.5 bar and 5.0 bar respectively , apparently high on the front because I prefer this on driven wheels , and a little extra on the rear in case I make an error in loading
unfortunately a large percentage of motorhomes in europe are overloaded , and consequently there have been failures which people blamed on the tyre manufacturers ; there now seems to be an undisclosed agreement between the manufacturers that for a motorhome they will always quote the maximum pressure of which the tyre is capable and this protects their commercial interests ; at the same time the ETRTO have withdrawn their load/pressure charts , a copyright document , from the public domain ; they also try to persuade vehicle manufacturers to fit larger tyres than are needed , in case of excess [ and illegal ] loading
however here is a link giving the information you need
http://www.motorcaravanning.com/tyresafe_mh_tyres_08.pdf
there is a member on this forum who was involved in a fatal accident , fortunately he was not to blame and his vehicle was found to be correct in all respects when examined
if you do not know your axle weights how can you be sure you are in the same position ; excessive tyre pressures are dangerous just like low pressures
hi on the plate under bonnet it has 3200 kg
5200 kg
1 1690 kg
2 1750 kg
on the tyre it has 215 / 70 R 15 C 109 - 107 Q
BTW If you are involved in an accident and the Insurance company assessor finds that your tyre pressures are set wrong then your insurance can be null and void. That can be an expensive lesson.
As for manufacturers recommendation, when I had the Elddis Autoquest 120 the problem I had was this:
On the door post the pressure was given as 80 psi. At that pressure the handling was atrocious and my teeth rattled when I hit a pothole. Plus all the crockery etc made such a noise that it got on my nerves.
On the Elddis website, it said 43 psi. At that pressure, the tyre looked almost flat and the handling was even worse. The moral of the story is: TAKE NO NOTICE OF ANY STICKERS REGARDING TYRE PRESSURE.
The recommended pressure (by Michelin) was 55 psi at an axle loading of 1600 Kg per axle.
fine , you have plenty of tyre for the maximum weight
question is , what load are you actually carrying
you should load up and go and weigh up , say half a tank of diesel and half a tank of water , all passengers [ or at least adjust for their weight after !]
presuming you are not much over those weights I would try 4.0 bar front , 4.5 rear , ample until you find out exactly what you are carrying
you now have the official figures and can ensure that you conform to the tyre manufacturers figures [ doesn't matter which manufacturer , all conform to ETRTO loads ]
incidentally , if you find you have weight problems , it is possible that you can get it uprated a little , with a new plate ; later models had a higher rating on the same chassis if I remember correctly
5200 kg
1 1690 kg
2 1750 kg
If you are not sure what the figures mean, then I should explain.
1690 Kg is the max loading allowed on the front axle
1750 Kg " " " " " " " rear axle
3200 Kg is the MIRO (mass in running order)
5200 Kg is the maximum permissable train weight (weight of van + weight of trailer)
If you add 1 and 2 together, you get 3440 Kg. Subtract the MIRO (3200 Kg) and you get 240 KG left. That is what you can carry in the van. That figure includes passengers and goods and may not necessarily be very accurate. That is why so many vans are overloaded. The manufacturers and especially the dealers often tell porkies when asked about the carrying capacity of a vehicle.
I have in the past contacted Michelin technical department & they were helpful in telling me what pressures I should be running based on the axle weights.
maingate , am afraid that is not correct
3200 is the maximum weight of the vehicle fully loaded , what it weighs empty taken away from this tells you the load you can carry
the reason the total weight allowable on the 2 axles exceeds the total allowed for the vehicle is to allow some flexibility in loading
if we stop now i can say lebesets last statement is correct. i have been in a fatal accident where the other driver was killed .i was exsonerated at the inquest for trying to mount a grass bank to get out of the way . it did mess my head for awhile as the press always blame truck drivers .get your tyres something like it dont overload . if you had heard the inspection that was done on the vehicles you may be amazed .you need the right tyres at about the right pressure .yes ask the manufacturer if you can i worked for michelin for awhile they will always get back to you . i just say play around the pressures arent quite a fixed figure they do vary depending on wether its a truck or carrying passengers. as comfort does play apart in it.
Hi Lebesset,
I stand corrected.
The problem with this is that not all manufacturers apply the same criteria when giving maximum weight.
Some use a full water tank, 75% full fuel tank and include the weight of the driver (approximately). Others do it slightly differently.
There have been a lot of complaints from m/home owners on websites that they have been shocked at the weight of their van when they have weighed it. It is not surprising that they have had the weight upgraded. Many have had little choice, otherwise they will be breaking the law.
its a shame that the weight as been brought down with licence laws i always thought merc got it right with the 508. just about right for a camper 5ton.
if you want max weight it as to be with full tanks and every thing else .then have 200kg spare as every thing you buy or extra pdeople will soon mount up. 3.5 is not enough really. vosa know its easy so makes a good target.
cheers alan.
for me alan is correct in principle...but wrong in the detail
when the 3.5 tonne law was introduced the vehicles were much less sophisticated than they are today , no power brakes , no power steering etc ; plenty of vehicle for anyone to handle on a car licence; now a 3.5 tonner is like driving a car , little physical effort required
but what has happened is that our motorhomes have changed , much more equipment , much more weight , even bigger people ; whereas once a 3.5 motorhome would carry a tonne of load , now you would be lucky to get half of that
so I don't see the problem as a decrease in weight to 3.5 , rather a lack of an increase to reflect modern vehicle technology ; the vehicles that most of use drive today are actually designed to run at 4 tonnes or so , all that is needed is to increase all the regulations to that ; there is no reason why not ...vehicles would remain the same overall dimensions , and don't tell me that a bridge that is marked to carry 3.5 won't carry 4.0 , they are actually marked that way to fit the legislation , and for motorway tolls etc they would be carrying the same vehicles
it will come too late for me , but as always it will need political pressure ; where is the political pressure in the uk ?..there are beginnings in france and germany I understand
note however that the new government is going to ignore all current petitions to number 10 ; those petitions were sent ,not because of who the government in power was , but because they were issues that people thought needed addressing ...if this is an indication of the attitude of our new masters , heaven help us ; listen to the people ? not this lot either
a lot of work to change everything ? not at all , just a quick EU law saying that all signs, licences etc currently designated 3.5 are henceforth legally able to be used by 4.0 vehicles ; then change all the signs , paperwork etc when they came up for renewal ..if that took 20 years , what would it matter ?
the 3,500kg limit only came in in uk 1997 vehicles havent changed that much. germany changed at the same time as us .they could drive up to 7,500kg on a car licence before then. yes france was different and some others were but that didnt effect us. i still say 5ton is ideal for a camper. specially if long terming.
i like mine could be 9.6ton if i voluntary lift the train back up.
i voluntary down it so pre 97 lic holders can drive it.
its possible with mine to lower the gvw to 3,500kg and still keep the train of 9,600kg and be driven on a b+e car licence.
laws and rules all confused yet?
cheers alan.
the only difference is that when you pass your driving test you no longer get a C licence in the uk [ since '97 as you say ]
what constitutes the various categories has remained unchanged since , if I remember correctly the late 1960's ; I remember being given a 16 tonne licence on grandfather rights when these categories were introduced
in france the 7.5 tonne licence was withdrawn in early 1975 , and reduced to the 3.5 tonne unless you passed a hgv test
my point is that the ..no vehicles over 3.5 in this town , or over this bridge , extra tolls , lower speed limits etc has existed for many years , and in my view is outdated in the light of improvements in vehicle technology ; this has nothing to do with driving licences as it applies no matter what heavy licence you hold ; the licence , of course , needs updating so that it covers the vehicle up rating , but is not the raison d'etre
