Motorhome trim needed
Alberto
Hi
Looking for 5 meters of trim that fits between the side skirt and the wall of the motorhome, see attached image.thanks for looking.
Al
Hi
Yes I did try Google lens, with no luck, lots of trim, but mainly u-shaped ( after I blurred out the calipers).
Motorhome is 2002 so maybe obsolete now?
Al
What make of motorhome?
I know that with Autosleeper you can contact them with your vehicle build number (sticker placed inside the glove compartment at time of build) and they will tell you if various replacement parts you might need are still available. 🤷‍♀️
Ours is 2003 and I've tried the online Autosleeper parts system for a couple of replacement things in the past 2 years.
Hi
Al
Good evening. I have recently found out that with the help of a GmbH in Switzerland I can open my own business in Switzerland from the United Kingdom - https://swіsscompanyformation.com/articles/blog/gmbh-in-switzerland-comprehensive-guide-to-formation-benefits-and-legal-requirements-in-2024/ . I really liked this guide because there is a lot of useful information here!
Nice clear pics — looks like you're after trim to fit a 22.3 mm gap between the side skirt and the wall. Might be worth checking with motorhome suppliers or caravan accessory shops that do edging or finishing trims in rubber or flexible PVC. Some even offer samples so you can check fit before buying the full 5 meters.
Good luck finding the right one!
Is this an AI generated reply?
New user joined 1 minute before replying, calc re gap wrong as my measurements show trim 20mm wide -so not to cover a 22mm gap and the suggestion to try dealers is obvious.
Apologies to replier if I'm way off mark
Al
It's a Compass Buccaneer 750, not sure if they are still going.
Al
Made by Elddis at their Consett factory.
Good luck contacting Elddis 😱
When i needed a part for my Compass i contacted the dealer whom i bought it off said i needed to contact the manufactuer i.e. Compass who in turn said they did not deal with the public and i needed to contact the dealer who said no i needed to contact the manufacturer and so on, never did get the part :mad:
Might be worth having a look at o'leary motorhomes, they have a lot of bits some of which are unobtainable eleswhere.
I never bought another Elddis van for exactly the same reason.
Nothing to do with camping but may have trim that could be used - very helpful so you could send them an inch of your trim to see if they could get it or get it made. Not cheap cheap but never over expensive
Thanks, they have one in white that I could maybe use in place of original, not as wide but probably wide enough.
Thanks again, Al
