16" Wheels
Hi,
I fitted a set of 16" Merc wheels to my S660 a couple of years ago. They give you much more stability and a better cruising speed. Roughly, you knock the speddo out by about 4-5 miles mph at about 60mph; ie, the speedo showing 60 but actually doing 64-65mph.
With the wheels you end up with about 12" more rubber on the road. You need to make sure the tyres are no more wider 205 or they will rub the back springs. If they do you can either scrape of the rust and grease where the springs rub or, failing that, get a set of merc washers and fit them to the drum before you fit the wheels.
The only difference that i have found is the vehicle takes a litter longer to get started when on steep slopes due to the lack of power and the bigger wheels taking longer to rotate. Other than that its all good with no problems.
I was insured with Comfort and now the Camping and Caravan Club and informed both about the wheel size. Neither changed the policy nor made any complaint. I think the van also looks better and wonder why 14" where fitted as standard.
I thought they made such a difference that when I found another set of 16" wheels at the scrappy I bought them as well and intend to fit them on the next Hymer I buy -- which will be in the next couple of years when my wife thinks out 1986 model needs a "modern feel" and we hopefully go full time -- although I will be sorry to see mine go as I have spent so much time messing about and fixing things on ours you end up loving them, albeit
skint!!!
Regards, Tgee
