typhoon
Does anyone know what sort of current drain your average leisure battery would allow for short periods without cooking the plates.
I know you can't start a car with one as the starter would take anything from 400 to 600 amps. I'm using an 1100 watt inverter on 2, 85Ah leisure batteries wired in parallel but I'm a bit scared to use the inverter to its full capacity which would mean drawing about 50 amps from each battery.
I have an 800w toaster and that's worked OK but so far I've been shy of using a 1Kw kettle, preferring to use the gas instead.
