Pudsey Bear
I thought maybe £3-5k PHEW!!!
Here’s a realistic estimated total cost to fit a used automatic gearbox into a 2007 Fiat Ducato that currently has a manual gearbox — based on UK market prices and typical labour rates.
You’ll need to source a used or reconditioned automatic gearbox that fits a Ducato (likely a late‑model automatic unit). A couple of price examples from UK/EU part listings:
Realistically, for a decent used/reconditioned automatic gearbox, budget £600–£1,800+ depending on condition, warranty and source.
Because of this complexity:
£3,000 – £8,000+ depending on workshop and complexity.
Based on discussions among Ducato owners and mechanics:
1) Parts Cost – Used Automatic Gearbox
You’ll need to source a used or reconditioned automatic gearbox that fits a Ducato (likely a late‑model automatic unit). A couple of price examples from UK/EU part listings:- Used 9‑speed automatic gearbox (tested, in stock): ~£425–£515
- Other automatic gearboxes for Ducato (varies by year/spec): £1,500+
(auto boxes for newer models or higher spec vehicles are more expensive)
🛠 2) Labour & Fitting Costs
This isn’t a simple drop‑in like replacing a gearbox with the same type.Important feasibility note
Converting a Ducato from manual to automatic isn’t just swapping the gearbox — it likely requires:- Different transmission mountings
- Torque converter (not part of a manual gearbox)
- Modifications to bellhousing / engine coupling
- Possible ECU remapping or replacement for automatic control
- Change to pedal box, shifter linkage, wiring harness, possibly sensors
- Possibly different driveshafts and electronics
- Road‑worthyness / certification concerns
- High street garage labour could be 40–100+ hours of specialist work
- Labour rates for skilled transmission work in the UK commonly £60–£120/hr (varies by region)
- A shop might need to source or fabricate parts, programme the ECU, test and adjust everything
3) Total Estimated Cost
| Cost Component | Estimated UK Cost |
| Used automatic gearbox | £600 – £1,800+ |
| Transmission ancillary parts (mounts, sensors, linkage, wiring) | £300 – £1,000+ |
| Labour & programming | £3,000 – £8,000+ |
| Total Estimated Cost | £4,000 – £11,000+ |
Important Practical Reality
Based on discussions among Ducato owners and mechanics:- A manual‑to‑automatic conversion on a Ducato is very complex and rarely done simply because it’s so expensive (many advise it’s not worth it compared with selling and buying an automatic van).
- The parts may be available, but the integration of electronics, driveline, and control means significant custom work.
