johntalbot
johntalbot
hi there just bought first camper talbot having probs with the heating can anyone help please thanks john
More information required. What sort of heater? Gas or Diesel? What have you done so far?
i will try if you let me know whats wrong
power
water
gas
whats it not doing or doing
Hi John,
I sent you a PM a while back with my contact details on. If you want to pop down with the van I can have a look at it for you. Two heads are better than one as they say.
I have a Hospital appointment this afternoon but the weekend is free if that suits you.
power
water
gas
hi thanks for your reply, its a talbot 19 diesel ,got no heating from engine when driving its running cold , dont know if matrix is the problem , put new pipes from radiator to engine in case they had collapsed , have got new thermostate ,but not put it in yet with bad weather,any advice is helpful thanks john
Hi John,
hi thanks for reply could not get back to you been busy trying heating in camper and not been on the net , yes i will pop down , will try to get down at week ends thanks, will let you know ,but busy with relative at minute as she poorly.thanks john
flush all your heating circuit through 1st, if you can ,remove your matrix and give it a good flushing out,reverse flush too checking for leaks! don't put your new thermo in til you've done that.
i have an ldv and the heaters are atrocious but i gave mine a really good flush out and then the induction pipe i changed for a flexi one so during cold weather i put it above the exhaust manifold so warm air passes over the hotter matrix instead of cold air having to be heated up, its improved the heating.:)
hope this makes sense and helps
have a look on the floor, up forward and central under dash. Have you got [hidden under carpet] a large gas tap type lever?. Some talbots have this as an on/off for the heater instead of the use of the slide control on the dash heater controls. It took me ages to suss it out on my van. I found it when replacing the carpet after suffering the heater being on all summer. HTH.
Paol.
sorry you didnt make it that clear for me i thought you ment the gas water boiler like a carver in the rear of van
