EMPTAGE123
Hello, last year I got 2 solar panels connected to my battery via a regulator. The battery is also connected to my inverter. When my solar panels are generating alot of power usually showing near 13amps this on the solar regulator (24v 30 amp regulator) suddenly drops to 0 and the inverter will then bleep and power out from the inverter stops.
It seems to me as though the solar regulator cuts off to prevent battery overcharge as the appliance being used is only a small drain but why is this also causing the inverter to stop supplying the device? I have a kill switch to stop power coming from the panels to my regulator and if I turn this on so no power is going to the regulator then to battery, the inverter works perfectly okay and doesn't beep unless the battery is low so I know that the panels are charging the battery fine and my inverter also works. Please help
