Phantom
I currently have a Votronic stand by charger to charge SB from LB via solar but it seems insufficient for my purpose as not getting a decent enough voltage at SB from it, but then SB and LB are over 6m apart.
I think instead a better option would be to use a battery combiner such as the Victron Cyrix as well as the Ablemail 30A B2B which is already installed, though not both at the same time! When parked up with solar the battery combiner seems to be the ideal option. Though when travelling the B2B would likely be best. So how to have the best of both worlds? What is the best way to wire them as I guess only one could be used at any time to avoid conflict, so likely a switch or two are needed? LB and B2B are together in MH garage with a decent sized wire to SB. Maybe not the usual set up but guess it should be quite doable.
