I just wonder, does the hot weather affect tyre pressure. Do I need to increase/decrease the pressure slightly? I had a rear tyre blow a few years ago, and i'm not anxious to repeat the experience.
Use a good quality pressure gauge and adjust the pressures when the tyres are cool, before you have driven on them.
The difference caused by varying air temperature is smaller than the inaccuracy in your pressure gauge and the guesstimates of the correct pressure.
My car has a sticker showing the correct tyre pressure for the rear tyres.
The same tyres, in the same conditions, but with different loads and speeds, have recommended pressures varing from 29psi to 46psi.
As a tyre heats up so the pressure will increase, Sue. Having said that the effect is small for a tyre in the UK (even in current conditions) and probably about the sort of variation you'd get between pressure gauges anyway. Then if you factor in variations in tyre manufacture, tyre materials..........
Nothing to be concerned about in my view. Strangely enough I calculated the change in tyre pressure due to temperature variation for a member at Attleborough a couple of weeks ago. I'll run you over it at the next meet we're both at if that would reassure you. I promise the calculation is not difficult to follow.
Colin![]()
I presume you were applying Boyles Law.
How did you work out the Volume? Or did you leave it as a constant?
