BeeJ
Just preparing my Swift Suntor 600B for winter store and on the last button press to retract the step - it didn't! It retracts on ignition start up but then won't work using the rocker button. Any ideas anyone?
thanks for this Keith - microswitch appears to be OK as I can hear a 'click' when I push it in and let it out.
Brian
manufactures recommend these steps are not greased as the grease will collect mud and grit making the whole step tighten up. remove al bolts and bushes, clean off and put back DRY.Get a can of spray on grease. If the linkage is starting to get tight, it will not fully retract or deploy.
WD40 is OK to get it freed but you need something better to keep it that way.
