Barnesnz
Hi all,
my name is sean barnett im a kiwi lad travelling around europe this summer with 7 other mates from home and im in spain now and having a few problems that i need to overcome if someone can explain
firstly now we are in a 1999 mercedes diesel 614d bus 4,200cc, i have installed a leisure battery setup off the 24v system, let me tell you what i have
a 220a/h leisure battery connected off the 1st of the 2 12v starter batterys with a manual switch to disconnect when not driving, ive just bonded the earth of the leisure to the chasis rather than the battery, the starter batterys are connected in series to give 24v. off the leisure i have some 12v sounds being a 1600w amp 395w rms, 4x 6x9's. Then i have a 600w 1000w peak true sine wave inverter, off that I have 230v appliances of course, those being a 70w fridge, a 140w icemaker and 120w off fans.
Now what has happened so far is the ice maker and fridge when tryed to start would drop the inverter below 10v and would cut out, i thought the leisure battery needed more time to charge however not the case while in france we were driving along and the sounds started cutting out and the inverter with just the fans running, then the bus started cutting out then died and smelt a elec burning smell, alternator gone. Did I overload it? we now have a new 1 fitted and the leisure battery is still not charging, i need it to as am in europe for 3 months.
Now what i have since found out is that u cant charge 12v batterys or use 12v appliances of a 24v system by coming of the 1st battery?? ive heard that you need to get a 24v-12v dropper transformer, if this is the best way what type, Size etc?? or if there is a better suggestion out there, now also is my load to big in this case and if I get the leisure battery charging correctly and start putting full load on the alternator while driving do i risk frying it again, should i just get rid off the icemaker maybe??, possibly the amp too to reduce the load
ANY HELP ON THIS WOULD BE SO VERY MUCH APPRECIATED AS YOU CAN IMAGINE NOW ON THE ROAD TRYING TO FIX IT IS A PAIN ON MY TRIP, SHAME ONLY GOT THE BUS BACK 2 DAYS BEFORE LEAVING LONDON SO TEETHING PROBLEMS HAD TO BE FOUND OUT THE HARD WAY ON THE ROAD!!
HOPE SOMEONE OUT THER CAN HELP OR CAN GIVE ME A CONTACT ANYWRE THAT COULD EXPLAIN WHAT I NEED TO DO
Many thanks,
Sean Barnett and the rest of the boys
Many thanks,
