Moped
I have noted that several larger portable power stations have 12v 25a Anderson outlets. These can be used to power your 12v system in your camper or motorhome as an alternative and more efficient way than using the onboard power station inverter with a hook up arrangement.
Given the original equipment leisure batteries are already fitted and wired in, I was thinking that using a 3 way switch (off, battery 1, battery 2) and placing the switch between the inline fuse and the leisure battery, it would be possible to wire the Anderson lead and the leisure battery leads to the switch that enables you to select either the leisure battery or the portable power station to run the 12v power circuit. You might need two switches, one each for the positive and negative circuits to and from the leisure battery.
Has anybody done this with a power station Anderson outlet port and if so how have you set up the connections to run your 12v system?
In the way I have suggested or another method?
In fact has anybody done this type of fix for any secondary 12v power source using an either/or arrangement where they require one battery to be portable?
