This 'free' member will be quite willing to share this info with all on here, but we're just leaving the house for a meet in Arnside.
Will post pics etc on my return.
regards
Allen
Great meet with the C&CC at Arnside, we even had a bit of sun. You southern softies should be careful what you wish for, 'cause it's affected us hard lot up north !
Anyway, hopefully I'm attaching some photos of my recent Gaslow Install.
(I see that they've uploaded, but why are they thumbnails & not 'full size' ?)
The filler has been located in the aluminium skirt adjacent the gas bottle locker. I've then braced the filler assembly back to some underside chassis using a small section of aluminium angle.
The hardest bit was cutting the hole in the skirt for the filler. It's about 3 1/2 inch dia, which I marked out undersized, stitch drilled (must've been about a hundred holes), then opened up to a good tight fit using a hacksaw blade and a half round file.
At the back of the filler there's a 90 deg fitting, then the fill pipe up to a T piece on the 1st tank. The filler pipe for the 2nd tank comes off the other branch of the T.
I cut a hole through the side of the gas locker for the filler pipe. I'm going to edge this with pipe lagging.
1st fill I got nearly 40 litres in (there was a little bit in one of the tanks from last use over 2 years ago).
I didn't leak test (soapy water) 'til the day after, and then discovered a tiny leak from the 1st joint in the fill pipe at the T on tank 1. I nipped the backnut a far as I dare, but it still leaked, so I disconnected all the fill pipes.
Obviously, then all the pressure in the fill pipe escaped, so I reconnected. I then leak tested again just to make sure gas wasn't escaping from the main inlet valve of the tanks and pressurising the pipes. It wasn't.
I'm thinking that I'll strip the fill pipes off again and make the joints with a gas sealant. Anybody tried that ? Any other suggestions ?
The install took about 4 hrs.
regards
Allen
