Hi Again
I have just taken this info from the hymer club site which may be some help to you. :-
Pull Down Bed Gas Strut Replacement
"WARNING THESE STRUTS HAVE VERY HIGH PRESSURE RAMS"
This procedure can be done by a competent DIYer
To replace a gas strut it is very important to make sure that there is no residual pressure on the locating pins. To achieve this, the bed must be set and held as high as possible, using the travel strap. I found it easier if the bed was emptied including the mattress.
The split pins were then removed and the strut checked that it was fully extended by being loose on the location pins. I then carefully removed the drum end, pointing to the back of the van first. This to ensure that if there is any residual pressure remaining, the strut it would be travelling away from the windscreen. The new strut was then fitted in the same position and split pins re-located to secure the strut before lowering the bed.
I was able to do the above from the inside of the van, but some may find it as easy to do the above from outside by leaning through the driver's door and the sliding window.
I would recommend that both struts are changed. It is sod's law that you will remove the stronger strut first.
I obtained my replacement gas struts from Peter Hambilton, but I have since found that they can be obtained for approximately £32 + vat each from:
Billington Group
280 Bawtry Road
Wickersley
Rotherham
South Yorkshire
S66 1JY
Tel: +44 (0) 1709 543837 email:
frank@billington-group.co.uk
Bye for now
Freddie:wave:
