Gas Fridge
Shuker
When running our three way fridge on gas it keeps turning itself off. Any advice would be greatly appreciated
Make and model would help.
Possibly the thermocouple is defective - the flame out protection.
If it lights up ok but goes out after a while, it could be that the thermocouple is not positioned correctly. The flame needs to heat the thermocouple to keep the gas valve open. On most modern fridges the flame size reduces as the fridge cools down, it may be that the thermocouple has moved a bit so that the reduced flame doesn't keep it hot enough.
Another possibility is the the jet is partly blocked or there is a bit of debris on the burner, either could mean that the thermocouple is not kept hot enough.
AndyC
Sorry for the vagueness of the post, model is Electrolux RM 4207 Electronic ignition
thanks for the advice will have to check
OK now we need some more details!!!
When you turn onto gas the piezo electronic igniter should start to spark - often you can hear it.
If/when the gas goes out after a few seconds (upto about 30) the piezo should start up again.
If it does not start then there is a problem with the electronics - not much can be done DIY other than checking that all of the 12V connectors are providing a good circuit. Its not uncommon for the spade connectors to build up a layer of oxide which prevents continuity so just unplug them one at a time and re-seat them to establish a good contact.
If the piezo starts once the gas has gone out, then its likely (as said above) that the thermocouple is responsible for your woes. On startup the electronics override the gas out function of the thermocouple and will produce a larger flame to get the fridge going, the flame is then "turned down" for running normally. Initially try moving the thermocouple into the flame, check that the outer copper sheathing is not damaged or badly twisted, if there is a lot of soot on the burner give it a clean with a stiff brush and vacuum.
After that its off to a repair service!!!
