fuel pipe leaking
Brandyman
wanted rubber fuel pipe connects from fuel filler pipe to tank ,
any help would appreciate
my van is a talbot express 1990 it's 2" diameter with slit bend.
brandyman
most or all motor discount outlets sell the pipe .if not a main dealer will help ah just seen you live in the orkneys ,try going on e bay under veihcle parts and accesories hope this helps
Yes thanks My van Talbot express 1990 find it very difficult to get pipe .
Wen did or where did you see me live in Orkney.
hi in your location it says orkney islands or have i got it wrong (that is easy for me) have you tried no1gear that guy has most things fot talbots if not preloved has a talbot owners section
Pipe leaking ?
Brandyman ,your ' location ' is stated at the top right of your posts....
The pipe you are searching for is ? the fuel FILLER pipe ? the big round one ? any scrapyards where you are ? or car shops as many makes or models of car would probably fit,what about the ' yellow pages' under rubber pipes or similar (for your area )even good old gaffa tape wrapped around a bicycle repair patch over the offending pipe thats leaking (tip) but of course to take it off first..usually held on by large jubilee clips ?That is if its the correct pipe we are on about...good luck.
Yes Orkney Islands thanks again the pipe is 2"diameter slite bend
Hi thanks found pipe no1gear had one that's a we glass of highland park when we meet
once again thanks cheers. Merv
glad you found the pipe thats what we are all on here for to help by the way cheers for the drink no1gear is the man to try for the talbot and other vairiants of that model
