orian
Are folding solar panels any good? Would 7 or 15 watts be any use with 110amps battery?
Any advice would be welcome.
You can work it out yourself, you will get about 1 amp in good sunlight, so a very long time for any recharge, merely top up!
That is of course unless you have a week or so!
I had two of the suit case jobs and single 20 watt on my boat, it was useless!
I put mine back on ebay and looked at other options, for any reasonable charge you should look at a hundred watts or more!
You will need a little regulator to prevent over charging for around a tenner or so from Maplins!
A lot of rubbish written about solar panels, work on the principal you will get only 25% of the claimed rating in reasonable sunlight will be about right!
I'd just start the campervan up for a while each day, the alternator will recharge the battery fast enough. 500 quid buys a lot of vin ordinaire!!
u could buy a small jenny and top up when ur by no-one or in a noisy enviroment!!!!
Thanks for the suggestion but my unit is a high top and I really don't have room for a jenny whereas I could have found room for a folding solar panel.
Good for you not intending to get a Genny...... I would get at least a 50 amp.... I have a 43 amp and i wished i had got an 80, but when finances permit I will put another 43 up there, as if one should play up, I have a back up.
Saying that though the 43 amp has done all I wanted and if and when my leisure batt starts to fail i shall put in a 110amp that should sort me out.
Another method of cutting your usage is to change all your bulbs to l.e.d that will cut your consumption by 70% lighting wise.
Biggest problem is that the standard alternator is not designed to fully charge a deep-cycle battery in any reasonable time. Yes I know that some will say that is not true and given enough time an alternator will charge a battery to full capacity but I did say "reasonable time". Then we can have the argument as to whether a standard leisure battery is really deep cycle or just a re-labled starting battery
To use a typical example of a 100Ah battery that has been discharged well below the safe level of 50% (for a flooded lead acid type). Running the engine at fast idle for say 1 hour might put a whole 20Ah into the battery if you are lucky - and so might bring the battery up to 50% charge. Once in a while this is OK but if you continually have a battery only half-charged, the life may be short.
An EHU will only look after the battery properly if it is a proper three-stage charger. Some are converters and others are taper chargers and these may not give good results. A solar system with quality regulator will also do a perfect job of battery care.
It all comes down to what your camping habits are likely to be. EHU every three or four days using a quality charger and no computer or microwave and other heavy loads, and a single 100Ah battery will likely suffice. Sitting in the forest for a week in the middle of winter and no amount of solar will help. Then a small generator and a thick skin might be essential. Driving for a couple of hours every couple of days and charge from the engine and you will also survive quite well.
No universal answer.
Whether you have AGM or Gel or deep cycle or hybrid (marine) or starting flooded lead acid also will result in different answers.
