izwozral
mind thats a bit big for those batteries hope you dont flat them.
Is that the true power or peak,many are not advertised correctly,and what are you wanting to power.
Reading Allans web page will give you some ideas of what's best practice. http://www.WEBSITE BLOCKED BY ADMIN/inverters.phpA 600 watt toaster.
i use an inverter to power my fridge freezer .or the twintub washing machine.why do you want an inverter ?
Remembering the 50% depth of discharge rule, you only 90ah to play with if your batteries were new. If your inverter was 100% efficient and it's not, that toaster would be pulling in excess of 50 Amp hrs
I was talking about capacity rather than a moment in time, but if I'm wrong thank you for the correction.Sorry to pedantic but that should be 50 amp not 50 amp hrs.
Bit big to run a toaster ,i would have used the gas grill,to each there own.
[/QUOT
You should note that generally with invertors they will draw the current required by you appliance, plus a little bit for inefficacy.
Unless you set up your system for high outputs then gas or EHU is better for heating/cooking
See next post!
Just use gas to toast unless your on electric hook up.I didn't understand half of what Allan was saying in the link you provide but what I got the gist of, is that using an inverter isn't such a good idea unless you have a large battery bank which will then require a large solar set up and no doubt a better solar controller than the one in my MH.
Hmmm, methinks I have further thinking to do.
