Exhaust rubber O ring
kimbowbill
Both the large O rings that hold the exhaust up have snapped, i am having real problems finding ones to fit, i am going away at the weekend i have thought about using women's tights :scared::scared::scared:as a temp fix, do you guys have any other suggestions, keep it clean please :lol-053:
Really? You local garage or parts dealer can't source the right size for you? What vehicle? I just replaced mine recently, cheap & easy to replace. Of all the parts on my MH these must have been the easiest & cheapest to replace!
Don't mean to sound like a douche.. its just hard to imaging not being able to find the right size stretchy rubber ring!
its true, ive even been to the place that made the exhaust, thinking, they have to have them, but they don't stock anymore, i have one more place to try, SDL i have looked on ebay, called in at exhausts fitters, garages, i wouldn't be asking on here if i wasn't having problems
Have you looked on eBay ? As there are some universal ones on there that are quite long with a series of holes so that the are as the title says universal, failing that try at a commercial garage as they must be bigger for trucks/wagons, or maybe cable tie two together
Hi, mine break every two to three years. Get replacements from ABS (Auto Battery Service Ltd) in Rochdale. I think it is a national company, so you should have one nearby.
If you're not already using it for a car aerial, use a wire coat hanger until you find some.
There are over 800 different rubber exhaust support rubbers listed in use today and of them many are rings.
http://exhaustpartsuk.com/index.php...escription=1&keyword=Exhaust+Rubber+Mounting+
If we knew your van type we could help more. Rings can be changed out to a stronger support - see above. I had a classic that needed an unavailable support and I ended up using a small length adjustable vee-belt [we keep this in http://www.bearingshopuk.co.uk/belts/nutlink-belting/ ]
I have used belts from electric hand planes when someone has a persisting breakage.
I had a similar problem with my 2003 2.8 JTD, nobody local stocked the rubber hangers.
I took one down to my local Euro Car Parts and the chap took it into the stores and came back with the closest matches. One of them was a Volvo part that was twice the diameter and much stronger. I bought a couple of them and fitted them. It took more effort to get them on but as far as I know, they are still going strong and are about 6 years old now.
Its a Talbot Express see post 11 in cracked window
Alf
If we knew your van type we could help more. Rings can be changed out to a stronger support - see above. I had a classic that needed an unavailable support and I ended up using a small length vee-belt [we keep this in http://www.bearingshopuk.co.uk/belts/nutlink-belting/ ]
Pop into any Kwik Fit garage and they should sell you a couple or any motor shop. Ladies tights are not a good idea, possibility of catching fire when driving.
My experience of Fiat x250 exhaust mounts. I noticed mine where broken so replaced with new from a motor factor 9 months later they got an advisory at MOT so ordered some more from another motor factor who gave me a choice of 2, genuine Fiat or some by another maker but advised the genuine where much better having had several complaints about the others so I went for the Fiat ones just looked and still not even a crack to be seen after 3.5 years down side was twice the cost for the Fiat ones initially but money well spent to day
Here you go Kimbo, get about 3 packets because they are rubbish. If you use the van all the year round you are lucky if you get 12 months out of them. I suppose it would be no good for profits if they made them to last.
.... Tom ....
Talbot Express Fiat Ducato Exhaust Mount Set Peugeot J5 Citroen C25 | eBay
Thnaks Tom, i ordered these last time and i couldn't get them on, the problem i have is the exhaust is custom made stainless steel and the hangers are, well, not aligned, i would have to send you a pic its hard to explain,
