Bigpeetee
We have a Kontiki 2001 on a Ducato base, 2.8 ITDT engine.
Last year in the cold spell, the cab heating was poor and the engine never got to a good working temperature.
I replaced the thermostat, the replacement being the same as the old one had a "Joggle" pin in the bypass hole in the thermostat.
It has always taken a long time to warm up, maybe 4-6 miles to get any reading at all on the temp gauge.
In the summer, the temp gauge rises to the mid position and is stable.
Now that we're using the cab heater cause it's getting cold, the engine temp never rises much, only if going about 70 does it rise up a bit more, but drop speed and the temp drops.
We were caught in blizzards last December (after I changed the stat) and as we were just crawling along, the heater was barely luke warm.
I presume therefore that the heater matrix is fed directly from the engine and that the fan in the heater is dissipating the heat faster than the engine can create it??
I've driven down the road and turned off the heating and the engine temp rises slightly. The radiator is warm but not hot (the bypass hole in the stat is letting some water flow)
NOW; are my assumptions correct? is there anything I can do to increase the engine temp?
Most longer distances I'm pulling a trailer so am limited in speed to 50/60 depending on road. I'm concerned that as the engine isn't getting up to temp, it's not doing it the world of good. It does drive 52 weeks of the yr.
Any thoughts??
Any thoughts??
