Emptying Fuel Filter Ducatto 3.0l 2012
  • Thread starter Thread starter Deleted member 58330
Anything in particular I need to know about emptying water in fuel filter? Do I just unscrew the white tap at the bottom? Does it reprime itself? Thanks.
2' in the picture is the drain/bleed screw.
The drain nozzle is directly below it on the base of the assembly - you'll need to attach a length of tubing.
Edit - just to clarify, nothing comes out of the drain/bleed screw, it just opens/closes the nozzle below it.
I found it works best when ignition is left on as diesel is then under pressure in the filter if you decide to change it heres a utube video YouTube
great many thanks.
