benk
Wondering if anyone has had this issue and if they can help pinpoint where the fault is.
I have a self build camper with a Dometic CRX50 fridge. It's powered by a leisure battery which charges via split relay as well as a 200W solar.
Initially after fitting the fridge I found that it would sometimes have the warning light to display that it wasn't receiving enough power. I fitted the solar (which was my plan anyway) and this fault stopped.
More recently my solar panel failed and I was only alerted to this when the fridge started cutting out again. I've had the panel replaced and it's working fine now, the fridge however continues to be temperamental, (I'm now living in the van full time) sometimes displaying the warning light that it's not getting enough juice. I first thought this was just at night or not in direct sunlight however its now done it a few times when I can see the solar is up and running fine. For example yesterday I was testing the fridge, the panel was working and in direct sunlight. The fridge worked but I was turning it on and off a few times to make sure the switch didn't have a loose connection and all of a sudden it started displaying the low power fault. I waited a few minutes, tried it again and low and behold it worked.
I've checked the leisure batter and it is good (12.65v I think) and been advised that it should have enough power in it to power the fridge without the solar.
Unfortunately I can't easily get to the back of the fridge to check what voltage it's getting but I'm fairly sure I used decent wiring to avoid loss of voltage however to me either loss of voltage or a fault with the fridge seem like the most likely option?
Anyone else had a similar issue or have any advice?
thanks
Ben
thanks
Ben
