Private
The paperwork that comes with your CRIT' Air certificate is in English on the front, but in French on the back.
For my own pedantic requirements I chose to translate it & I have copied the results here to help fellow pedants; others will just pull the sticky thing off & put it on the windscreen.
Literal Translation:
Operation mode for vehicle with windscreen.
Clean the inside of the windscreen at the bottom right.
The surface must be clean and dry before application.
Peel the whole by the back of the document and stick it on the cleaned area.
The certificate must be visible from the outside.
Once it is glued, do not try to reposition the set otherwise the certificate will tear.
Genuine English:
Clean your windscreen on the inside in a bottom right position.
From the back of the paperwork, carefully peel back the square sticky patch from where it says “Detacher ici” & ensure the circular certificate comes with it.
Apply it to the inside of your windscreen so it can be easily read from the outside.
The certificate will tear if you try to reposition it.
Operation mode for vehicle without windscreen.
1. Remove the patch that is on the front of the mail.
2. Take off the certificate delicately (attention the surface is sticky).
3. Return the certificate and place it in the same place.
4. Peel off the assembly from the back of the document.
The certificate shall be affixed, face-up on the outside, to a surface in the front of the vehicle in a very visible manner.
(fork, mudguard, front right rack)
Genuine English:
Remove the non-stick patch from the front of the paperwork.
Carefully remove the circular certificate, turn it round & put it back in the same place but now with the back showing to the front of the paperwork.
Stick it on the front of the vehicle e.g. on the front fork or mudguard with the certificate face up.
End:
_________________________________________
Source (or sentence by sentence translation):
Mode operatoire pour vehicule avec pare-brise:
Nettoyer l'interieur du pare-brise en bas a droite:
La surface doit etre propere et seche avant application:
Décoller l'ensemble par l'arriere du document et le coller sur la zone nettoyee:
Le certificat doit être visible de l'extérieur:
Une fois colle, ne pas tenter de repositionner l'ensemble sous peine de voir le certificate se dechirer.:
Mode operatoire pour véhicule sans pare-brise:
1. Enlever le patch qui est sur le recto du courier:
2. Décoller le certificat delicatement (attention la surface est collante):
3. Retourner le certificat et le positionner au même endroit:
4. Décoller l'ensemble par l'arrière du document.
Le certificat doit etre appose, recto visible a l'exterieur, sur une surface situee a l'avant du vehicule de maniere tres visible.
(fourche, garde-boue, carrenage avant droit):
Detacher ici:
Detach here
Genuine English:
Genuine English:
End:
Detacher ici:
Detach here
