Nabsim
I know at least one person on here is running a calorifier for hot water so would like to pick their brains.
I have a Sprinter based coachbuilt that has been changed quite a bit from original by previous owner(S). The hot water is produced by the engine coolant going through a single coil calorifier. They had the system professionally installed and spent a wad on it, if I keep moving I have constant hot water no problem at all.
I like to park up out the way though and stay a while if i like it though. There is a 5kw Hydronic built in that heats the engine coolant when ignition is switched on but only with ignition. I want to change this at some point so I can run it independently but so far haven’t got a good enough understanding to snip wires. The USA Sprinter forums are somewhat contradictory on how best to do it.
I like the look of these combined air/water heaters from China and thought they may be a good back up system for both my D4 and Hydronic. So that’s the layout and reason now the question.
can I tee into the exiting Coolant pipes to add another heat source or would I need to change to a twin coil calorifier? The later would mean at least double the cost which won’t be happening. If tee in is okay would I need to add an additional pump, I presume so, and would anything else be required.
A kettle is fine for me but when Mrs is with me she likes running hot water. The calorifier is currently fitted with a 1Kw immersion but never been wired in and too big for my 1Kw genny I expect. I did get a 300w 12v immersion I was going to fit to use excess solar but as solar is doing nothing really since around September this year I don’t think it worth doing.
