Blasted water
antiquesam
Water is the bane of my life. I seem to spend my life stopping leaks at home and in the van. I'm away for two weeks and the Sureflo pump has sprung several leaks. I've tried putty with little effect. Now I've emptied the tank and I've bought 25 bottles of water. I'm on my own so I don't have to be too fuzzy.
New pump ordered and will be home before me.
Welcome to the age of spastic plastic. It had to happen apparently. Most of it is built to replace these days, one must bear in mind also that it does go through seasonal variance unlike domestic products.:idea-007:
Get some of that black rubber tape on a roll. My tool kit consists of Bailer twine, self tappers, a screw driver, old hover cable and rubber tape and thats it. Fixes everything from leaks to broken exhausts in a knackered old Kontiki.
do you mean self-amalgamating tape ?
Ah, Bailer Twine. NZ is built on that stuff! I was introduced to no.8 bailing twine whilst over there and fixed the hab lighting, broken bed, door catch and gas cooker in the wreck of a van we hired. Brilliant stuff, in fact I actively went looking for things to repair such was it's versatility?:D
Every farmer knows the value of orange bailer twine. Entire farms are held together by it.
Barry, have you now ditched the sledge hammer from your toolkit?
I think you're confusing baler twine with no.8 fencing wire, twine for temp fixing,no.8 for permanent repairs.:D
Anything you can stick on will only work as well as it sticks. That will only work as well as the thing it is stuck to.
In general, I've found Miilliput reasonably good, or Sugru if you need flexibility. But to waterproof a joint, self-amalgamating tape is good as long as it doesn't have to withstand pressure.
Overall, patching and bodging is just a way to ensure you have to keep mending over and over again.
Why has the pump developed a leak? Exposed to sunlight? Cleaning chemicals? Impact or vibration?
I'd try to find the cause of the failure, fix it then fit a new pump.
Fix it properly, fix it once.
I think I said originally that I am away and have sprung a leak, hence the bodge.
I've ordered a new pump, which will be at home before me.
As to the cause. I don't use chemicals in my water system and like most it is hidden away in a cupboard. I don't know what to do to stop vibration as it is fastened to the body of the van by four screws other than not drive it.
For all I know the pump could have been in place for the 24 years the van has been on the road, but that is unlikely as the leaking bits are plastic and not bakelite.
