freelander
I have a 1980 motorhome with a 2.4 mercedes diesel engine and have been told that this machine will run on used cooking oil! Has anyone ever tried this or have any usefull information?
i think just about every man and his dog as tried running on veg oil if you travel alot . better in hot climates but sometimes its dearer than diesel. central heating oil with engine oil added and just about every other fuel you can think of . i use a drop say 10 litres of petrol in with my diesel its cheaper than diesel and help it burn clean. not evry tank about 1in 5. but sometimes not worth the hassle. fill up with bio diesel at some pumps thats usually rape seed oil.
Hi Freelander don't know if it helps but heres a site about it,
Using Vegetable oil as a diesel fuel
al
I have exactly the same engine in my Autotrail Apache. They will run on used cooking oil, but if you do this there are a few things you need to do / be aware of:
1. Used oil is full of bits so needs to go through a filtering process dowwn to about 1 micron to remove the rubbish..
2. Due to its viscosity being different to diesel and the lack of additives they tend to perish the rubber seals on the fuel pump. Once replaced (not cheap) they should then be OK.
3. Veg oil tends to clean the fuel system and lower your emissions. While this sounds good in theory, in practice it has led to mine cutting out on the motorway as the gunge worked through the pipes.
4. In cold weather you need to reduce the mix so you have a higher ration of diesel:veg oil otherwise you will have starting problems.
It's your choice, but personally having been there and done it quite seriously for a while (even registered as an official fuel producer), the difference in cost between it and diesel is so little I wouldn't bother.
On the positive side - if you're willing to work through all the above and can find a cheap (or even free) supplier of oil from your local chippy, takeaway etc... then you can be onto a very good thing, especially if you buy the preheater for cold weather (or make one yourself).
If you go to pocuk.co.uk (Mitsubishi Pajero Owner's Club) you'll find loads on there about it and lots of links to very informative sites.
A friend of mine has ran his car on used veg oil for several years.
He started out by setting up a collection round with local chippys resturants etc.
He gave them labelled containers and all the correct paper work ( waste disposal note), this then gave him a supply of free fuel, but you have to collect every week no matter what as they need regular removal of this waste.
He has a tank that he stores the dirty oil in to allow it to settle out so you can drain the water off the bottom.
Then he filters it ( he sells the filters etc on Ebay.)
His car has two tanks he starts off running on diesel then once the engine is up to temp it switches to the veg oil tank this is heated by the engine cooling water. the only down side is you need to switch back to diesel a few mins before you turn off or it would be almost impossible to start on pure veg.
Now initially it was a lot of work but his cost is only a few pence per liter.
New veg oil is just too expensive
