ALDE 3020 HE problem -2015 Bailey AA745
r4dent
Just back from a break. On our first night away we had EHU so the heating was on Electric, no problem.
Yes I know this isn’t Wild Camping but the pitch had a private Hot Tub and it was Valentines and we did have bubbly in the fridge!
Second night we were in a Pub car park with no EHU and switched the heating to gas.
After a few seconds the power light went red and we got the warning message "Fan Restarts".
According to manual "Fan restarts: Incorrect fan speed. New start attempt is made. Repeated faults results in ‘Fan failure’. If Fan failure recurs after resetting, contact a dealer. If Fan restarts is displayed, no action is necessary."
So I did nothing. Sure enough the message went away and the power light back to green. However after a couple of mins the fault reoccurs, then goes away , then occurs, ad nauseum.
At this stage we didn’t get the "Fan Failure" message.
After consulting Dr Google I did a few checks.
1) I have Gas and it is switched on everywhere,
2) Boiler fuse OK (swapped it with another just in case -neither is blown);
3) Coolant level on “min” so I added a bit
4) Cleaned exterior exhaust outlet;
5) Hab. Battery level OK
So we abandoned the break and came home. I thought the drive would shake things up a bit and this often sorts things out!
This morning I’ve connected the EHU at home to see if anything has changed.
Heating is fine on EHU, but as soon as I put the gas on the problem happens after a few seconds.
I have had the “Fan Failure" message a couple of times but this is cleared by “Reset” on the control panel.
When I switch the gas on the fan varies between 2000 & 3,000 rpm. then goes to 0 when it fails and back to 2000 - 3000 for the restart.
We are out of ideas.
Any thoughts or suggestions? :help:
It seems that your Fan error problem is a known problem and if you check the 'error messages' section of the handbook, it is referred to.
It is telling you that there is a problem with the flue fan, so it would seem sensible to start by assuming there is a problem with the flue fan. Why do you think otherwise?
Thanks guys. I realise that the message refers to the Flue Fan, but the manual says the fault will clear itself. It does clear itself but then fails again after a minute or so. The monitor shows the fan spinning at 2000 -3000 rpm between fails so I don' think it is a jammed fan. I suspect either a sensor or PCB problem, I was hoping someone else had experienced it and could advice on the problem. I don't fancy replacing fan / PCB & sensor but it might come to that.
The first thing to do is to find out whether there really is a problem with the flue fan. If it seems OK, check that it isn't a flue fan sensor problem. Then look into the possibility that the more expensive bit is faulty.
Any suggestion how I check the fan is OK. I get a rpm reading before the fault occurs, but I don't know whether the fault causes the fan to stop and the speed to drop to zero, or the fan stopping causes the fault message. If I have to get a new sensor and a new fan and a new PCB I might be as well getting an new complete unit (with fitting = £1500) and having a lot of spare parts.
