Advice needed with a non starting Dometic Freshlight 2200 AC unit
dave docwra
Can anyone help with a problem I have with a Dometic Freshlight AC unit failure, or can reccomend a Dometic engineer close to the East Midlands area.
The fault is that it starts & sounds to go through two fan start up stages, then as soon as the fan speeds up in a third stage it then sounds like something
is locking out & it shuts down, showing a orange LED lamp instead of green, whilst attempting to start the lamp goe's from permanent orange to a flash of green
then flashes orange for fifteen blinks then shuts down.
Thanks Dave.
The flashing light sound like a diagnostic fault code ....ring dometic they are quite helpful and have a service centre Derby/ Notts area
Channa
Before you do that see if the manual tells you or a label on the unit normally on the inside of the cover,,,,,it could be lots of things if it hasn't been used sfor a while ...earlier units were susceptible to voltage sensors failing and inrush currents playing havoc from what I can tell
Channa
Doe's anyone have a contact number for Dometic customer services, every Dometic repair agent I have spoken to, either states they do not have the equipment to regas the system or they do not get involved with the units, I strongly feel it is an electrical fault & doe's not need regassing.
Thanks dave.
When I had a problem with a Dometic aircon unit, the Dometic-approved service people clearly were not interested. They were dismissive about such an old unit being worth looking at.
I took it to a car aircon repairer. They put their aircon machine on a four post lift and raised it to the motorhome roof level.
The problem was just that it needed a regas. Wellhouse Leisure had claimed to have done that, but the valve was rusted up. Hadn't been touched.
This only has one port (not a high and a low pressure port) and uses a Schrader connector, but that shouldn't faze a good aircon engineer.
Of course, if yours has an electrical derangement, it may be different. But it could just be an out-of-bounds sensor reading.
So perhaps you should forget a Dometic person and look for a vehicle aircon specialist.
Your suppositions assume the system is on R134a ( vehicle refrigerant) if it is an older system odds are a different refrigerant ,,,,Agents may well steer clear but dometic themselves in the Derby area
Channa
Thanks dave.
Google turned up this page:
Dometic UK Ltd., Blandford St. Mary | Dometic - Mobile living made easy.
The phone number given is correct for Dometic UK.
0344 626 0133
Hopefully they can help.
I will have to learn to read a bit better !
Thought Dometic had started making Fleshlights :lol-049:
Thanks for all the replies.
The system is a sealed system with no connections for servicing the refrigerant, the refrigerant used is R407c so I believe that rules out the automotive repairers. The guys in Derby think that it may be a electrical board failure but are not sure with this model, all the other Dometic service centres I have contacted within a 100 mile radius of me do not work on these units.
Thanks To POI the number listed is useful & I have spoken to customer services who in turn will talk to a technical person who in turn will hopefully ring me back.
Thanks again Dave.
Automotive repairers are indeed ruled out, for a couple of reasons one of which is it is not used in cars ( that I have ever seen) Best bet a local air con engineer that possibly services the pubs etc Lot of the older fridges used R407 C.
Sealed system can be overcome, using Schrader valves , evacuating the system ( requires capture of the gas garages wont have the receptacle possibly the correct manifold gauges.) The OFN pressure test repair if required and recharge the system. However what it doesn't do is overcome a PCB fault only dometic can help with that. Worth costing a replacement pcb ? if you are determined to get the system wprking.
Channa
On a more general note, what is the future of aircon?
The gas they're now supposed to use is so ridiculously expensive that it will push the price back into the luxury zone, unless the price tumbles by a factor of ten.
Then there is the issue of flammability. Those weedy little aluminium pipes don't look safe for the stuff in the event of a road accident.
Channa?
Totally my own opinion, But you ask the million dollar question ! Quite frankly If I knew a compelling answer I could probably make a lot of money.
In general terms replacement of equipment seems to be cost effective, for example HSBC bank has a £16 million programme to replace units in their offices, and early indications show a £2.2 million energy saving a year. Thornton the chocolate people have done the same Air Con important for integrity of their product and are enjoying similar savings in energy costs they discovered it a bit by happy accident after the Meadowhall floods of 2007.
Traditionally gasses like R22 were phased out and part of that phase out was cease of production, so only reclaimed gasses could be used then that was stopped rendering systems useless unless they could be adapted to accommodate the new generation of gasses ( a lot technically involved with
that) It is this scenario which is scaring a lot of car owners, and has you intimated on an earlier post R134A is the prominent gas .
From what I can tell the situation with R134a is significantly different, From 2020 -21 it will be illegal to supply equipment containing that gas but there are no plans to phase the gas out, so existing systems should be ok. That leaves us with a situation that such as the VAG group are now using R1234F to beat the deadline prices of the gas should drop as it becomes more widespread in use.
Generally the Montreal Protocol, Kyoto Protocol , introduction of F gas regulations and events as recent as the Paris summit have all shifted the goalposts, large r12 /r22 systems exported to countries traditionally like Nigeria and Pakistan but has those countries commit to agreements the final solutions are quite interesting.
The OP's R407 C is earmarked for phase out due to the fact it has a high GWP, That said it is an azetropic blend and is efficient at cooling , so if it does hit the radar it may go the same way as R134a.?
I am due for re testing, and there are so many changes with legislation I need it like a hole in my head. I do very little nowdays on Air Con that I am considering letting my ticket lapse and leave it to the youngsters, There is some real quality training out there, particularly to get women in the industry.
Channa
Thanks Dave.
I am wondering if there is a factory reset you can try always a possibility the electrickery has become corrupted. then give it a try nothing to lose. Ingersoll systems this was a common fault you could factory re set and it would work.
Voltage sensors and PCB repair not my bag wouldn't know where to start, but it could be as simple as a reset
If it does fire up and a gas recharge necessary we can address that, I have enough contacts to assist us
Don't lose hope,
Channa
Channa
