BABs
Hi looking for advice do I get a submersible pump and solar storage bag I have a shower cubicle but need help please
Il hold to xmas day.
use a pigtail on the end of a standard shower hose to connect it to a submersible pump https://www.ebay.co.uk/itm/12V-Wate...869095?hash=item5951f17967:g:ozEAAOSw~W9fCYhB connect the pump , with an inline switch and fuse , to the 12v supply . use a container , we have a 10ltr ,to mix up water to required temp, drop in the pump , switch on , get wet , switch off ,lather up , switch on , rinse off. cheap set-up and you can be as miserly or generous with the water as you want .
make sure the pump you buy fits into the container
Thank you for your help I have ordered the pump and have a container. Could you explain what a pig tail is please I am blondeuse a pigtail on the end of a standard shower hose to connect it to a submersible pump https://www.ebay.co.uk/itm/12V-Wate...869095?hash=item5951f17967:g:ozEAAOSw~W9fCYhB connect the pump , with an inline switch and fuse , to the 12v supply . use a container , we have a 10ltr ,to mix up water to required temp, drop in the pump , switch on , get wet , switch off ,lather up , switch on , rinse off. cheap set-up and you can be as miserly or generous with the water as you want .
best thing is to go into a plumber's merchant [not B&Q ] ,buy a shower fitting ,and ask for a connector to join the shower hose to hosepipe which will fit the pump outlet .to me a pigtail is a plumbing fitting with a corrugated end that is designed for a hosepipe to be pushed on and held with a hoseclipThank you for your help I have ordered the pump and have a container. Could you explain what a pig tail is please I am blonde
