ABS problem solved + A Handy addition to my toolbox
mid4did
Not sure where to post this so settled on the knowledge base as it's a problem solved post.
It started out with me wanting to swap my radio for a DAB version.
So down to my local Argos because thats where I found the cheapest readily available one and fitted the radio.Easy enough job with the stick on screen antenna .
Anyone thats done this knows the pitfalls fitting to a motorhome,weak fluctuating reception etc so plan B took it out and it's now in the car.
It may have been coincidence but since then The ABS light came on together with the engine going into limp mode,maximum 2500 rpm together with the speedo not working and the handbrake light on.
Looked on the renault forums(2004 renault master) and went through the usual checks including replacing a dodgy abs sensor cable front nearside.
I also got the faults looked at with my nephews snap-on diagnostic kit and he couldn't see the abs unit to see where the fault may lie.
Gave it a bit more thought and decided it must be a wiring fault to the ABS ECU or the ecu itself.
Down to see a mate who runs a small garage and got a printout of the ecu connector pins and wiring diagram and then went in search of the ecu.
Not so easy to work on the ecu ,it's above the first part of the exhaust.
Up on the levelling ramps to get underneath and it's a straightforward job to undo 2 clips,remove the 1st silencer,remove the heatshield above it and there you can see the abs unit.
It's then a matter of unclipping the ecu connector and getting the multimeter out to test for +ve and -ve connections ,also the cable up to the abd2 plug.
They all tested ok,in fact all the wiring and fuses tested ok.
I'd already found a firm in cullumpton who repaired these units but a phone call to them and I was informed they dont repair the ecu part and advised to try a scrapyard,or a main agent.
Luck was on my side and 1st phone call to a bristol firm(van services) who confirmed they had a unit £60+vat .
Long story short,I replaced the ecu part and problem solved.
Maybe not a job for the faint hearted but working methodically reaps rewards.
The addition to my toolbox was a Topdon diagnostic tool.It was then able to see the abs fault codes (From the 2nd hand unit?)afterwards and clear them,also helped me with another problem with the airbag sensor .Made in china but does the job plus emails the test results if required.
Cheap enough for the home diyer and no expensive main agent fees plus the old mans still got it though not so nippy these days 😁
Topdon Artidiag500
I heard a story years ago about a chap who lived in Crewe who owned an Hilman imp with rear engine and starter handle anyway one winter morning he backed his car out and reversed into a pile of road salt blocking his exhaust pipe, so he got his starting handle and pushed it up the exhaust pipe and started to turn it to remove the road salt.
Just at that minute a police car comes by and sees him with the starting handle up the exhaust pipe the policeman gets out and he breathalysers the man thinking he’s drunk early in the morning.
This was told to me by a joiner on the building site I was working on at the time in 1977.
John.
Very interesting. I have tried several diagnostic tools, to read a Renault Master fault codes, but none were compatible. It seems that a Renault "Can Clip" tool, is necessary, so I spent £100, on a Chinese copy of the "Can Clip", and haven't been able to get it to work, so it was a surprise to learn that the "Topdon" was able to read the codes.
Might buy one, myself.
I was the same.I was told about the can clip too butI looked at topdon and icarsoft .
I settled on topdon and somehow managed to get it for around £75 after ebay put a special offer deduction on it.
It does the same job on my 2001 skoda octavia,reads the vin code on that one.
icarsoft diagnostic scan tool
topdon renault master Inspection report
Unfortunately, for me, I don't think the Topdon was available, when I bought the Chinese "Can Clip" copy. It was about 10 yrs ago.
Last time I needed to look at a fault on the airbag system I couldn't find anything either
Bring back simple things and the perkins 4108 or the 6354, no electrons were harmed in this thread. 😂 😂 😂
i had a 6354 in a combine harvester....sat 11.5 months of year, stick battery on fill with water....an good to go. cut the corn park it up , drain the water put battery back in the digger an leave combine till next year.
