Pudsey Bear
I was just thinking that IF I had a few bob by some chance, I quite like the newer Bailey motorhomes as they are quite well built and a lot have the Ford automatic engines, but not happy with this wet belt malarky, so I thought I'd ask Google for info on disasters.
Are there any reports of the Transit EcoBlue engine with the wet belt going bang?
AI Overview
Yes, there are extensive and well-documented reports of Ford Transit engines with "wet belt" (belt-in-oil) systems suffering catastrophic failures. Known as the EcoBlue engines (particularly the 2.0-litre diesel introduced in 2016), this issue has become a major concern for van owners and mechanics alike.
The Root of the Problem
The wet timing belt runs directly inside the engine crankcase, submerged in oil. If the oil becomes contaminated—typically by unburnt diesel from failed DPF (Diesel Particulate Filter) regeneration cycles—the diesel chemically degrades the rubber of the belt. This causes the belt to delaminate, swell, or shed its teeth.
When the belt degrades, detached rubber particles often block the oil pump strainer, causing a sudden drop in oil pressure and starving the engine of lubrication. Ultimately, the belt can slip or snap completely, causing the valves and pistons to collide, which results in catastrophic "bangs" and severe engine damage.
Common Warning Signs
Users on Reddit's CarTalkUK community heavily discuss these premature failures, noting that they frequently happen between 50,000 and 80,000 miles. Watch out for these early indicators:-
Recommended Action
Due to the severity and expense of these failures—which can result in massive repair bills—industry experts and independent mechanics, such as HallCraft Servicing, strongly recommend replacing the wet timing belt and oil pump belt far earlier than Ford's original, longer service intervals. The widely accepted best practice is to replace both belts every 5 to 6 years or between 60,000 to 80,000 miles, whichever comes first
AI Overview
- Low oil pressure warning light: Often the first sign that debris is blocking the oil pump.
- Unusual noises: A distinct ticking, slapping, or whining sound coming from the front of the engine.
- Engine misfires or rough idle: Caused by the belt stretching and throwing the valve timing off.
- Rubber debris: Mechanics often notice rubber particles in the oil filter during a service.
Recommended Action
