Drain it, better safe than sorry, most places have a tap to put a few drops in to test.Nope! Mines off on Friday to my motorhome fixer as it has a leak from the Kitchen drainer pipe and a very small occasional one on one of the windows so ill need to keep water in it. I Don't think its going to be cold enough yet up here to worry about it.
Leave mixer taps open in the central position and lay the shower head on the tray, leave plugs out.
So long as the pipe can drain leave it the van in the kichen sink on a bit of paper or a cloth to stop scratching, one less thing to remember.
Don't forget the water traps on the drains - screen wash additive will prevent freezing and potential damage.Don't forget to drain the toilet flush tank if you have one.
Don't forget to drain the boiler.
Don't forget to leave all taps open .
If any one needs help draining opened bottles of whisky / rum /brandy that is what this group is about.
Will an open pipe be a problem if it freezes? it can expand along its length.
It might be a good idea to go for a drive on a bumpy road to get the last dregs to go lower after a drain down, then try again.
If you dont have solar then make sure you float charge all batteries including starter batt 24/7 if laying up the van, that way your eyes wont water and freeze at the price of new ones.![]()
Solid pipes like copper etc wont freeze and split if there's an open end reasonably close, say within 6 feet. I've never seen a flexible plastic pipe such as the push fit pipes we see in houses or the blue and red stuff used in MHs split, there's enough give in the pipe wall to take up the expansion.Will an open pipe be a problem if it freezes? it can expand along its length.
Make sure you float charge all batts.Good point. I checked my app the other day as I remembered I hadn't shut down the vans electrics / sargent system but all good so far. Still fully charged parked out front. Ill shut it down completely when it goes on the drive over winter. I'm not sure we will go away in this Christmas unless the weather suddenly looks great.
I had to fix a open copper vent pipe for c heating in a loft once, should not have burst but it did big style.Solid pipes like copper etc wont freeze and split if there's an open end reasonably close, say within 6 feet. I've never seen a flexible plastic pipe such as the push fit pipes we see in houses or the blue and red stuff used in MHs split, there's enough give in the pipe wall to take up the expansion.
