Well first of all you are doing the right thing using your van in winter. Winter offers some great scenery, it’s much quieter, you will be more welcome in some honeypot summer locations, and it’s not good to leave a van for months on end sitting on your driveway or elsewhere.
First pick your days if you can, check the forecast and avoid periods of relentless wind and rain. The colder the better for me, some of my best trips up here in Scotland have been in frosty weather when it’s been down to minus 15c.
1) if using Calor gas make sure you use the orange propane and not blue butane. Butane won’t function in low temperatures.
2) if your grey water tank is outside and not insulated and heated consider leaving it open in sub zero temperature and collect the grey water in a suitable container.
3) remember that even bright days your
solar will be much reduced in winter. Consider fitting another
battery if you only have one, and lithium batteries which can be used down to 10% capacity offer more usable energy than lead batteries. But they may require modifications to your charging system if you have an older van.
4) if you have external covers use them. They provide better insulation, and prevent excessive condensation. If you don’t have a set consider buying them.
5) keep your van warm even when not inside it when out and about, I don’t allow the temperature to drop below 10c, this prevents any freezing of pipes within the van.
6) make sure you have sufficient food in case you are stranded due to bad weather. We carry additional canned foods in winter. Also ensure you have sufficient drinking water, and gas or diesel for cooking and heating purposes.
7) it’s more critical that you take notice of weather forecasts, constantly keep checking them.
8) when you return make sure that you carefully drain your whole system. This includes the boiler and your tanks and water pipes. This involves running the pump and opening all water openings including ones you may not have used including external showers, toilet, taps, and internal shower.
