Deleted member 56601
To get away from the childish bickering and back on subject. I use and can certainly recommend Trojans as good wet cell batteries.
Just as it was getting interesting .To get away from the childish bickering and back on subject. I use and can certainly recommend Trojans as good wet cell batteries.
Me too Chris would highly recommend trojans if you want lead acid and can carry the weight.To get away from the childish bickering and back on subject. I use and can certainly recommend Trojans as good wet cell batteries.
Most chandlers stock them
After reading this thread, I went onto the Alpha Battery site, with pen, paper and abacus . The idea was to work out the price per amp hour, in Agm batteries. I’d like to keep my storage around 300ah . Their Energy brand 105ah @ £120 works out at £1.14 per ah, while the 290ah @ £345 = £1.18.I am very pleased with a Varta LFD 230Ah Powerframe battery that I installed a couple of years ago.
I need advice as to which pair of batteries I should install in our motorhome. Ideally I wanted 2 x Exide 142ah but they are too long. Trying to keep the amp hours as high as possible with a maximum length of 330mm narrows the field down to a handful; rendering the handful down of other questionable brands there are basically two 120ah batteries; a Enduroline EXV135 and a Lucas LX35MF from what I have read on various forums both have been described as budget batteries (whatever that means) which is a concern. So I’m looking to establish which one of the dubious pair to buy. Or alternatively if anyone knows a better wet battery at a similar or better amp hour then please let me know. Alternatively let me know which of the two battery brands I should buy. Someone suggested Leoch batteries but again I don’t know if they are any good. What I do know is that the battery industry is full of skullduggery and re-labelling. That’s why I need some help. Thanks
I don't have a issue with weight (only my own I have full air suspension and plated at 4500 kg.Many coach built motorhomes have low payloads .the better quality the battery the heavier it is .I have 2x 105 LBs at 46 klg a 100 amp lithium way's only 14 klg for about the same usable power and much less space .that is the main reason I would consider lithium
Yes I deliberately said wet batteries, don't partially like them but I think they will suit what I'm trying to do now. I certainly don’t want to go to the expense at this point buying Lithium plus I don’t think the expense would end there with just the batteries as usually additional pieces of kit will be required to do a decent job (not wanting to kick off the bickering again as for AGM’s they would be a bit of a worry being totally sealed, we tend to travel south and with the batteries sighted under the lounge seat next to the boiler they will get warm; knowing AGM’s can create quite a bang if they get too hot I'm not putting them on my wish list. I will probably fit Lithium in a 2-3 years but now I just need the biggest bang for my buck within the space I have available. The problem with a lot of suggestions I have had is that they take the Ah down to circa 100Ah we are used to 2 x 140 Exide in our old Rapido and needed them at certain times when the sun wasn’t playing ball. Thanks for your interest.He did indeed (hence your suggest on the T105s ).
I did wonder why and asked specifically Wet Batteries. Maybe we will find out why he likes Wet Cells?
Any marine shop will have them,you also require a strap to hold the lid on,all should be fixed down.
Thanks for the explanation for your reason . I do understand your point ref Lithium - they are still a lot more than Lead Acid and the extra support items does push the total cost up for sure.Yes I deliberately said wet batteries, don't partially like them but I think they will suit what I'm trying to do now. I certainly don’t want to go to the expense at this point buying Lithium plus I don’t think the expense would end there with just the batteries as usually additional pieces of kit will be required to do a decent job (not wanting to kick off the bickering again as for AGM’s they would be a bit of a worry being totally sealed, we tend to travel south and with the batteries sighted under the lounge seat next to the boiler they will get warm; knowing AGM’s can create quite a bang if they get too hot I'm not putting them on my wish list. I will probably fit Lithium in a 2-3 years but now I just need the biggest bang for my buck within the space I have available. The problem with a lot of suggestions I have had is that they take the Ah down to circa 100Ah we are used to 2 x 140 Exide in our old Rapido and needed them at certain times when the sun wasn’t playing ball. Thanks for your interest.
We have four leisure batteries, 2 are approx 13 years old and 2 about 11 years old. I once asked Phil why they had lasted so long as some folk have to change every 3/4 years or even less. His explanation makes a lot of sense, When they are being used the load/discharge is spread evenly so they have never gone dangerously low which means they have had a longer life. As a numpty , it made sense to me.#After reading this thread, I went onto the Alpha Battery site, with pen, paper and abacus . The idea was to work out the price per amp hour, in Agm batteries. I’d like to keep my storage around 300ah . Their Energy brand 105ah @ £120 works out at £1.14 per ah, while the 290ah @ £345 = £1.18.
Therefore 105ah x 3 = 315ah for £360 . While the 290ah is £345. Pretty much the same, give or take. The advantage with the 290ah, to me anyway, is not having to faff around with putting 3 batteries in parallel.
That’s a long way around getting to my question.
I read somewhere, can’t remember where. That multiple batteries will give a better performance than one large one.
At the time it didn’t make a lot of sense, still doesn’t. Something like if one battery goes down, with 3 you can revert to 2. Then replace the duff one. That can’t be right. AlthoughI suppose if 1 large one, goes down your snookered.
Any thoughts? Although, not about the need for high amp hours. ‘Cos size matters.
( That’s what she said.
I think you had to be there.)
And me!We have four leisure batteries, 2 are approx 13 years old and 2 about 11 years old. I once asked Phil why they had lasted so long as some folk have to change every 3/4 years or even less. His explanation makes a lot of sense, When they are being used the load/discharge is spread evenly so they have never gone dangerously low which means they have had a longer life. As a numpty , it made sense to me.#
