Do you have a comment about the wiring ? I have 2 x105 amp badged. ?? Leisure
Battery's , about 4 years old when their time is up lithium is so tempting . also is the onboard charger compatible Sargent 328 . .at 14.4 volts
Not adjustable , as I'm sure you know the Sargent also controls the
solar to engine and LB
battery . 46 klg against about 14 is so tempting .
The way the Lithium
Battery pricing is dropping, it certainly has become a lot more affordable and worth checking out.
I don't know if the 328 Charger is compatible with Lithium. It is quoted as a Smart 3-stage Charger so it is likely compatible with the "drop in" style of Lithium Batteries, but maybe worth a call to Sargent Tech Support for their comment.
You do need to consider the low-temp charging aspect though as mentioned. A simple and useful way to deal with this if adding to an existing setup is to use a
Battery that will not just cut out charging at zero Celcius, but actually still charge BELOW zero. Alpha Batteries sell a version of the RB100 that can charge at down to -20C which I would think would be well within any realistic UK requirements
This is the model here -
https://www.alpha-batteries.co.uk/12v-100ah-relion-low-temperature-lithium-ion-battery-rb100lt/ . An extra £50 over the normal one, but saves the hassle of adding in extra temp-sensing wiring and adds piece of mind.
You could alternatively get one that has a BMS that cuts the charge if temp goes low, or add your own circuit to do this, but whatever the approach taken, it is important to make sure this is considered otherwise you could end up with an expensive brick.
When you say about the wiring and your comment "
...is the wiring could be too thin to carry the high current a lithium can take when charging ", I would hope that the wiring installed is suitable for the possible current the charger could deliver already? A Lithium
Battery charges much more efficiently so the charger could be providing the max current the charger can deliver for a longer time, so it is possible the cable could get bit warm if underspecced, but for say the Sargent 328, I think that is a 25A charger? and the standard Sargent cabling is usually 4mm2. I would say those two are perfectly compatible.
