StreetSleeper
Wonder if they will be making a Chinese copy of this
Webasto Air Top 2000 STC gasoline heater kit
Ideal for traveling or camping, the certified Webasto Air Top 2000 STC gasoline heater kit is the number 1 choice for space heating in the petrol vehicle market for a reason. This handy 12 V heater is compact in size, meaning it can be installed in a range of vehicles, and is especially suited for van conversions. The air heater’s size is so small that it can even be housed under the passenger seat for added convenience. But don’t let its small size fool you, this powerful little Webasto gasoline heater uses only 2 kW of power to provide up to 6800 BTU of heating.
Powerful it may be, but uneconomical it is not. In fact, you’ll find that this 12V heater is very fuel efficient, delivering 0.14 liter per hour to 0.27 liter per hour (0.036 gal/h to 0.07 gal/h).
And with a wide range of hot air ducting accessories available for this air heater, you can even transform it into a Webasto bunk heater. When it comes to temperature control, this air heater comes equipped with an integrated temperature sensor that will ensure that the heat stays at the level you have set. And if it’s enhanced heating control that you are looking for, you can purchase an external heating controller.
Produced and put together in the EU, this air heater comes from one of the globe’s most reputable brands that is based in Germany. So, you’ll have peace of mind, and not only that, with repair shops and spare parts available globally, you’ll not need to worry about maintenance.
Keys features of the Webasto Air Top 2000 STC Gasoline Heater Kit
You’ll find that everything you need to install this new edition of the popular Webasto gasoline heater comes in this easy to build kit. Perfectly suited to van conversions, this powerful 12V heater, is small in size but big in performance.
First off, let’s talk about fuel efficiency. This Webasto gasoline heater delivers an impressive 0.14 liter per hour to 0.27 liter per hour of heating (0.036 gal/h to 0.07 gal/h). The only 2 kW petrol/gasoline on the market, this little heater offers unrivaled flexibility. Its compact size means that it is small enough to be installed under the passenger seat. It also comes in a variety of outlet diameters (up to 75mm for 2 kW heaters). Not only that, there are a wide range of hot air ducting accessories available, making it perfect for transforming into a nifty Webasto bunk heater.
When it comes to controlling the heat, this 12 V heater comes pre-installed with an internal thermostat, and for more enhanced control you can purchase an external one. What’s more, this new model comes with on-screen diagnostics that give you a more comprehensive picture of your vehicle’s temperature. And if you are looking for that little bit of extra control, this 12 V heater is compatible with Rheostat (potentiometer), Multicontroller, ThermoConnect, ThermoCall, and UniControl. Finally, if you intend to be driving at high altitudes, this heater operates in altitudes of up to 1500 meters (5000 feet).
- All in one kit for easy installation
- Only 2 kW petrol / gasoline heater on the market, generating 6800 BTU of heating power
- Fuel efficient, providing 0.14 liter per hour to 0.27 liter per hour (0.036 gal/h to 0.07 gal/h)
- Smallest petrol heater currently available, making it perfect for installation under the passenger seat
- Wide range of hot air ducting accessories available, allowing you to transform the kit into a bunk heater
- Easy to maintain, with spare parts widely available on the market
- Internal temperature sensor gives you optimal temperature control
- External temperature controller is available for greater accuracy and control
- On-screen diagnostics give you a more accurate picture of your vehicle’s internal temperature (Multi-controller required)
- Several controller options are available – Rheostat (potentiometer), Multi-controller, ThermoConnect, ThermoCall, UniControl
- Shares parts with Previous Webasto AirTop 2000 models (S, ST)
- W-Bus communication used with Webasto U
- Shares same mounting brackets as Espar
- EC / EMC approved
