Hi,
Look at the charge regulator before adding extra panels a good Mppt controller whilst as expensive as a panel is at least 7 kgs lighter and could be as useful as an extra panel similarly batteries are seriously heavy lumps compared to an extra panel and probably more expensive than a panel. If you require an
inverter then you will need a large bettery bank.
You need to look at your lighting and if not already on Led swap to Led, again you could save the need for an extra panel, if you use quality LED arrays it will cost as much as a panel but saves lots of kgs in weight, if weight isn't an issue you have can choose which way to go.
Calculate your potential 12 volt usage by modelling your nightly needs then look at where you will be in the winter, your
solar wattage needs will be greater in UK winter than Spain winter, then work out your
Solar wattage requirements.
I put 200 watts of panel with a 300 watt Taiwan built Mppt controller(ebay purchase) and during the summer the system recharges our 110ah
battery before we are out of bed but in the winter it will struggle to fulfill this requirement during the whole day. I haven't felt the need for a 2nd
battery yet, we don't use an
inverter and we use 12 volt TV occasionally, I charge a laptop, Nexus tablet, phone and kindle reader all through 12 volt and do this during best light period of the day.
Your batteries are also recharged whilst driving and you should account for that when calculating your usage.
Good luck in your choice, the decision is yours but much can be calculated.
Clive
