I am not an expert but if you lift the bonnet, Fiat have seen fit to install a plastic engine cover? Under and over this is fan ventilated. I cannot imagine, thinking about it, that engine heat can be worse than
solar on my black car? I will carry out an experiment drive a good distance in full sun stop and feel the bonnet compared to other external car surfaces.
I think the figured (dimpled) plastic top cover of the panel is less reflective than the bonnet paint. I think that plastic would cope with a stone thrown by a vehicle better than my windscreen?.
Little fingers would not harm themselves poking, as all the wires would be under the bonnet. I was not quick to see what big fingers were but yes theft is a little more likely except they will not get semi flexible off in a useable condition quickly. My 160watt of semiflexibles on the roof have lasted 3 years with no problem. You can flex a semi flexible as a gentle cylinder or a gentle cone, not 2 ways at once. My bonnet is nearly only curved fore and aft, if I only use the middle metre. Any difference the other way is taken up with butyl putty strips of different thicknesses. Bolting the leading edge, (and trailing edge) down to stop aerodynamic lift and make theft harder is worth doing.
I think butyl putty and black stixall have stood the test of time. I do not know of more heat resistant spacer/glues. I would really struggle to get a failed panel off if stixall was used other than on edges, where a knife can reach?
I have a problem with an over used
battery after 3.5 years, but a larger lithium
battery should solve it and give an effective 25% increase in
solar area, due to better charging efficiency. If that is not enough I may add more
solar, my preference is the bonnet.
I like the light from the midi skylight so dont want to cover it. I might get a 50 watt thin panel alongside the skylight raised to top of skylight height to avoid shading but that is more difficult than the bonnet, or the moveable panel inside the windscreen, so that is my least best option.
