Mr B
In reply to your point, I can, as a trained Honda motorcycle mechanic tell you that the front brake lever pivot bolt is always a shouldered type on Honda, it’s not threaded all the way,this is to prevent over tightening as this might cause the lever to be squashed between the mount jaws, making it dangerous, it could make the brake stick on when applied. The torque setting is minimal, as the nyloc nut ( should be replaced every time it’s undone) is designed to not vibrate off.
I would much rather see a pivot bolt nut on the front brake a tad loose, but with a nyloc, than done up a half a turn past the recommended torque setting, the nut falling off will not cause problems, but an over tightened pivot bolt nut would be stressing its own threads.
So do you think in this instance the mot tester should have torqued that nut or just give it half a turn, possibly over tightening it and stressing the most important part on any motorcycle?
Clearly we are both far more qualified than the vehicle presenter who disputes the MOT tester tightening up a clearly loose nut !
It is not the actual nut or what a manufacturer might design or specify that is in question but the unqualified OP's opinion that the MOT tester was out to rip him off by first failing a clearly loose nut and then tightening it up at no charge to enable their unroadworthy vehicle to meet minimum roadworthiness standards that is laughable.
