Alice1
We have a Burstner t-star 680 on a Mercedes Sprinter 316CDI chassis (2004 & 64k miles) fitted with a sprint shift gearbox. Usually lovely, well behaved, and easy to drive. A couple of days ago it decided that it wasn’t going to play in auto mode and dropped into manual change only . Ok in reverse but it’s a bit of a bind having change manually all the time when it should do it automatically. It doesn’t show a fault on the dash display, just the number of the gear you are currently in. Changes down through the gears as normal (I.e. automatically) when you slow down for roundabouts or junctions etc. Also she doesn’t now like going up any incline and has to be coaxed up at low speed using the gears (like it’s in limp home mode).
I’ve looked on t’interweb for a solution, including taking fuses 3 & 8 out of the fuse box & replacing them (apparently a Merc dealer recommended fix ) but it’s no better. Next stop may be battery disconnect & reconnect to see if it reboots the ECU/solves the problem. From the research I think it might possibly be ECU related or maybe a faulty sender on the gearshift/box but before I take it to a Merc dealer/specialist to put on the computer diagnosis and find out the worst I just wondered if anyone else has had a similar problem? And if so how they cured it. it’s not a new box .
(BTW The same gearbox is fitted to VW Crafter vans too).
