MAF location??
1977paul
Hi all
Anyone know the location of MAF for 2003 Boxer 2.8hdi LX?
I have EML coming on when van under load, i.e uphill etc, engine stutters and light comes on.
No issues at lower revs etc.
Try as I might I can't find a MAF or an EGR valve to check/clean!!
Anyone able to help???
Cheers.
Snapster
The MAF will be in the hoses between the air filter housing and the intake manifold attached to the engine.
argoose
The only other option is no MAF but a MAP sensor screwed into inlet manifold
1977paul
Hi argoose
Def no MAF to be seen and I was aware of what they look like.
MAP sensor on inlet manifold and was found to be a little oily so cleaned up..... BUT I think the issue was a seized/stiff waste gate lever/rod on the turbo, loosened off and WD 40 applied and after 250 miles no EML appearing! Van appears smoother and the stuttering under engine load has gone.....fingers crossed!!
