Hot Water Options
JohnnysJAX
Hi My name is John and I'm soon to be converting a MWB 2013 Sprinter. I'm just wondering what my options are for a water heater maybe even a combi. I am probably going to have a small shower cubicle with a removable chem toilet and I'll also have a sink with running hot and cold water, hopefully. Cheers
An account upgrade is required to view more of this post.
GreggBear
Don't know about hot water mate, I don't got any in my bus unless I boil the kettle but welcome aboard anyway. Someone will no doubt have some advice for you shortly...👍😉
Nabsim
Hi and welcome, mostly people go for gas for heating and water but you can also use diesel, or a kettle. If you have a sprinter check under passenger headlight and see if you have a heater already in place for warming the engine. If so you could fit a calorifier like mine has but you would need to move each day to heat water.
vwalan
shower pods can be bought similer to these reimo used to sell. for the pump i have a weedkiller sprayer with shower attachment . works great . ideal for smaller vans etc . in my truck /trailer i use gas instantaneous water heater and a proper shower cubicle. on the old vw t2,s use the weedkiller shower behind the van with the back hatch up. and a waterproof curtain press studed to the hatch. worked for us for years .
JohnnysJAX
Thanks for the suggestions folks 👍 I am looking for more of a permanent shower cubicle type set up really
daygoboy
The simple solution is the Truma 10L gas/mains electric boiler £425? 2 heat settings, with a Shurflo 12v pump. If you look at Streetsleepers Thread on the Motorhomers site "LPG Tankless Water Heaters." He's sourced and about to fit an instantaneous wall mounted type only £60 or so. You have to be a bit cautious about using these in a van probably wouldn't want kids using them. Whatever you decide on don't be tempted by a Propex Malaga boiler!
JohnnysJAX
The simple solution is the Truma 10L gas/mains electric boiler £425? 2 heat settings, with a Shurflo 12v pump. If you look at Streetsleepers Thread on the Motorhomers site "LPG Tankless Water Heaters." He's sourced and about to fit an instantaneous wall mounted type only £60 or so. You have to be a bit cautious about using these in a van probably wouldn't want kids using them. Whatever you decide on don't be tempted by a Propex Malaga boiler! These sound like pretty interesting options for me and I'll deffo be having a look. Does the Truma 10L thing do heating aswell?
daygoboy
These sound like pretty interesting options for me and I'll deffo be having a look. Does the Truma 10L thing do heating aswell? No it doesn't, nice if it did for £425! But going for separate systems you have a lot of options on the space heating side of things, eg diesel Eberspacher or cheap Chinese copy, Whale/Propex gas fan, Truma gas fan and//or convection, take your pick! Plenty s/hand on eBay of course.
JohnnysJAX
No it doesn't, nice if it did for £425! But going for separate systems you have a lot of options on the space heating side of things, eg diesel Eberspacher or cheap Chinese copy, Whale/Propex gas fan, Truma gas fan and//or convection, take your pick! Plenty s/hand on eBay of course. Cheers 👍👍
colinmd
We have a Truma Combi4, great for heating and showers, but we never leave it running for hot water alone from the taps, it burns through the gas to keep the water hot, when running the heating there will be some heating of water, aside from that we will boil a kettle.
molly 2
We have a Truma Combi4, great for heating and showers, but we never leave it running for hot water alone from the taps, it burns through the gas to keep the water hot, when running the heating there will be some heating of water, aside from that we will boil a kettle. Yep works for me too. the heater is easy on the leccy and gas + 240 v ,it is a big lump with a big price . Adavantige of a diesel heater is you won't run out ,or run on red from a separate tank .
FULL TIMER
The simple solution is the Truma 10L gas/mains electric boiler £425? 2 heat settings, with a Shurflo 12v pump. If you look at Streetsleepers Thread on the Motorhomers site "LPG Tankless Water Heaters." He's sourced and about to fit an instantaneous wall mounted type only £60 or so. You have to be a bit cautious about using these in a van probably wouldn't want kids using them. Whatever you decide on don't be tempted by a Propex Malaga boiler! curious as to what problems you have had with the Propex Malaga, I've fitted a few in the past and had no trouble with them except on one where a water joint hadn't been tightened enough in the factory mind you the silly tiny nipple to attach a pipe to to drain down is a joke.
Markd
Diesel space heater definitely worth considering and the instantaneous water heaters are very good value . Should be able to get both for under £250.
delicagirl
just for info.... i have just bought a replacement Truma gas fire for the princely sum of £550 .... plus fitting costs... taint cheap this vanning lark......... i did consider a Truma gas fire/hot water-fire system but discounted it. For shower i do what some others do - in my bathroom i have a permanently fixed jerry can on the wall with a submersible pump. I part fill it with cold water and then top up with 2 kettles of boiling water and i have a great shower
