maingate
I was at a bit of a loose end this afternoon so decided to do a couple of small jobs on the van. When I had done that I turned my attention to a couple of old Fans laid about in the shed. They were bought for the car and used to keep the dogs cool in the back (no A/C fitted). They ran off 2 x D batteries and were therefore 3 volts. I also had a 240 volt powered voltage regulator you could set to a number of DC voltages between 3 and 9 volts (bought to charge up a camera battery but never really used). I rigged one up to the regulator, set at 3 volts and tried it and it works well.
So, my plan is to fit it behind the Fridge/Freezer for when the weather gets hot. I have a small inverter (about 80 watt) and will just use that with an adjacent 12 volt socket above the Fridge to power it. If the weather is that hot and sunny then solar power will be plentiful. It will be a 10 minute job to fit it and run the cable to it, much better than ordering computer fans and temperature sensors. The bonus being that I have upcycled components that would just have been chucked out eventually.
