Derekoak
I am hoping that being at least a month behind Harry and Phil I can learn and just follow the leaders.
However there is one area where I am installing differently. My battery will be underslung beside the lpg tank and diesel tank. That is where the existing AGM battery has been with no problem. So heating in cold will be more of a problem and an enclosure to protect against cold, knocks, stones, water spray and perhaps immersion will have to work harder.
On the other hand getting hot should be less of a problem.
So far I have decided that my 8 cells will be in 2 batteries of 4 cells in parallel, with 2 BMS, but all in one insulated waterproof enclosure, with the opening sealed lid at the top just under the car floor . They can then share heat. Apparently my maximum expected charge rate of 30 amp will only be 0.15C. At the moment even with the fridge small inverter, lights and everything on I will not discharge at more than 40amp = 0.2C. That scenario has never happened yet. Under these circumstances my research shows the cells produce very little heat. They may only be a degree or 2 above ambient. I think the BMS will produce more heat but I have no direct experience. They apparently get warm when they are discharging a cell, during charging, to balance the cells. The BMS have an aluminium finned heat sink but no fan I think.
My problem: Can I put them inside the waterproof enclosure to warm the batteries and be safe and use the wire lengths provided or do they need a different enclosure?
