Lithium batteries: construction and fundamental principles behind lithium battery cells as well as safety considerations
nordkyndesign.com
I was actually searching for information as to whether heating a cold lifepo4 would happen by conduction and convection or just conduction. According to this article there is no free flowing electrolyte in liFePo4 cells it is all absorbed so only conduction will occur in heating cells. The effect of that is that putting heat pads under a lithium cell is not the advantage that it would be in a flooded lead battery.
There is a lot about safety in this article. It also says
" Trickle charging causes all of the lithium present in the cells to be transferred to the positive electrode, whether it can be normally inserted into the carbon cathode or not. Any lithium that cannot be absorbed normally ends up plating the cathode.
From the above, it should be obvious that an operating regime combining fast charges followed by a trickle charging is particularly harmful. A fast charge tends to saturate the anode surface with lithium ions and then any additional charging results in lithium plating. This scenario can quite easily be met on marine installations where a focus was placed on fast recharging through the use of an engine and alternators (or high-capacity DC chargers) and renewable energy systems then fail to properly implement a charge termination and hold the cell voltages up."
I imagine a low float voltage helps stop the concern where the camper is not used and solar charges the battery to full. The sun shines and energy is always available to trickle charge the lithium but float of 13.6v is too low to cause lithium plating?
