bestyman
I have the usual set up of an engine battery and a leisure (well 2 actually) that are charged from the alternator when the engine is running.
I have read of the issue that when the engine battery is full the alternator sees no need to output a high charge. But why does the alternator not see the 2 batteries as one anyhow?
I have read about a Sterling battery to battery charger that overcomes this problem, but I think I may have a simpler solution.
Why not drive around with the vehicle headlights on, heater fan in full, things plugged into the engine cigarette lighter socket and fridge on 12 v. Surely the alternator would sense that it needs to output some power and thus charge both engine and leisure batteries? Would this work?
Ok that's my first question, but I have another idea too. What would happen if I plugged a small invertor into the cigarette lighter socket from engine battery and plugged a 240v car battery charger into this which was connected to the leisure batteries? The leisure batteries would in effect be getting charged twice at the same time. Would the 2 charging sources conflict?
Or would this work. Simply forget about the split charge relay and connect the batteries simply in parallel so both are seen as one and charged in no time by the alternator. When you park up flick a switch and isolate the starter battery.
Thoughts please.
Thoughts please.
