mistericeman
Latest update: switch on and after some time the pump works for 4 to 16 clicks and then stops, smoke from the exhaust but no fan working. Fan works fine when disconnected and running off battery and this is on 24 volts from 2 fully charged batteries.
Can you read the fault codes from the ecu with the controller you've got (701/801 types can)
Fan should pulse or run slow whilst the ecu runs its start up procedure.
