I think
solar settings will also play a part. Assuming the
battery has just finished fully charging , the mppt cuts off and the
battery voltage now falls back to 13.6v because that's the resting voltage of lithium. There's bound to be a slight drain on the
battery, even the BMS itself will draw a slight current, also the mppt, PDU etc. The point at which the
solar cuts in again and starts recharge will depend upon the actual design of the charger and if adjustable it's 'restart' voltage setting, depending on what this voltage is the
battery capacity could drop considerably because the discharge curve of lithium is so flat, just half a volt equals about 50% capacity.
So the mppt cuts back in and starts charging but there's not a lot of sun and the
battery only gets back up to say 60% before the sun goes down....what happens in the morning? Does the charger carry on from where it left off the previous evening or does it stay off because the
battery voltage is now very slightly over the restart voltage?
All very system and settings dependant but interesting...... probably not though unless you're me
