1 Cup
0 degrees in our town last night and now 5+ and sunny . should I tilt my solar panels to day. Has victron done its job ? It's to cold to go out and see.
Got your motor all sorted out JeffThis is live
How do I tell if low temp cut out worked ?
No Dave, it's home and I've lost the drivers door glass mirror also, it gos from bad to worse. The fuse box or location of relays fuses is just never dry always damp to the touch.but as it is under the windscreen looking for a way to seal above the fuses and find a solution. Mate.Got your motor all sorted out Jeff
Hi thanks My solar controller is above the driver's seat on the bulkhead and the battery is onthe floor behind the drivers seat. So 5 feet in height difference. Both with wood between the vans bodywork.If your battery and solar charger are next to each other then its saying its over 5C so no it hasnt resticted the charging. The Victron solar charger does not display its internal sensor temperature.
